Croissants
artattak
Croissants
Post by artattak »
In his free time, he prepares objects for visualizations.
Croissants came out today.
Gently used SSS on ceramics. And ready.
Enjoy your meal.
Cooked chef KRAY 3.037
promity
Re: Croissants
Post by promity »
Very nice render. Materials are used from a set of LW 2015 native materials?
artattak
Re: Croissants
Post by artattak »
promity wrote:Very nice render. Materials are used from a set of LW 2015 native materials?
It's a mixture of reflection and bump maps.
Very simple settings.
Take it easy.
promity
Re: Croissants
Post by promity »
Thank you for the clarification. I wanted to know exactly about the sss shader. I thought it was based on the LW material, it turned out that this is the K3 shader.
Re: Croissants
BTW Limiter recurse Node for reflection....no need use this right now 8)
Latest K3 is so fast that it doesn't mater for engine 5. 20 or 40 recurse reflection!
Watch my scene "Depp recurse tester"
Simply you can add Fresnel directly like I do now and I am not worry with 40 recurse (bounce lights GI also) to get black glass...(called: fail recurse)
promity
Re: Croissants
Post by promity »
So will all the native LW materials in K3 still work or will it be some kind of symbiosis based on some basic functions of the LW shaders and the K3 shaders?
How will the shaders be assigned in LW 2019 given that there are no tabs on the shaders?
Re: Croissants
promity wrote:So will all the native LW materials in K3 still work or will it be some kind of symbiosis based on some basic functions of the LW shaders and the K3 shaders?
K3 + LW15 no problems except: shaders and third part Node plugins...we do not support them (poor documentation, bad codes and bugs...waste of time)
K3 + LW19 same like above + whole new main shader system (Delta, Dielectric, BSDF, carpaint, etc)
Tab for K3 shader is under Motion Options (press "m" on object):
promity
Re: Croissants
Post by promity »
I thought it was a temporary solution. Are there any plans for Gregor to transfer his shaders to the material class (node based)?
Re: Croissants
promity wrote:I thought it was a temporary solution. Are there any plans for Gregor to transfer his shaders to the material class (node based)?
Yes. Probably he will create K3shaderNode. Now for him is easier to develop additional`s.
jdomingo
Re: Croissants
Post by jdomingo »
Is the latest version of kray compatible with LW 11.6? Please dont laugh
Re: Croissants
jdomingo wrote:Is the latest version of kray compatible with LW 11.6? Please dont laugh
Screen shot is from LW19.
LW15 has standard shader option.
ZodiaQ
Re: Croissants
Post by ZodiaQ »
Yes it is, I'm still on LW11.6.3 with K3.035 :wink:
