not working Kray 2.4+LW10.1?
Chumarin Ruslan
Post by Chumarin Ruslan »
Every time you try to render the scene fails, LW closed. This occurs in Ligtwave10.1. With version 9.6 works? Why is this happening?
Re: not working Kray 2.4+LW10.1?
Please select logfile and debug on misc tab and post your logfile here. We will also need simplified scene to troubleshoot the problem.
Alexis
Post by Alexis »
Hello, I have the same error. Here are my debug files on two different scenes.
In LW9.6.1, no problem
kraylog.txt
first scene
(2.68 KiB) Downloaded 460 times
kraylogescalier.txt
(606 Bytes) Downloaded 409 times
Thank you.
Looks like crash occurs during object imort. Coul you please send me the "reunion" and "Escalier" object?
Chumarin Ruslan
Hi! my kraylog files.
please tell me why I can not add an object to this topic?
kraylog.txt
(523 Bytes) Downloaded 303 times
Chumarin Ruslan
here is my another scene
kraylog.txt
(513 Bytes) Downloaded 316 times
boll.lws
(11.95 KiB) Downloaded 336 times
boll.lwo
(8.63 KiB) Downloaded 309 times
Chumarin Ruslan wrote:here is my another scene
You can send me objects to jure (at) kraytracing.com
Last scene you send has missing object www.lwo so i cannot confirm the crash.
Alexis
Post by Alexis »
After several tries, my scenes work. I started to zero in LW10.1 and it works.
If the scene is created in lw9.6.1, it crashes, I do not know why.
Thank you.
