Kitchen
Single
Kitchen
Post by Single »
this the first work which is not very shameful to show:) the commentaries of every kind and the criticism are greeted.
Post by silverlw »
Thanx for your contribution! I suggest you turn up blurred reflectionsamples much more to get rid of that dotty effect.
Single
Kitchen
Post by Single »
with the pleasure it would lay out entire scene for the testing, but there the names of objects the Russians:)
Post by silverlw »
Also as try this as antialiasing on a limited region for a start:
adaptive Grid aa 1x
change upsample to 1 (standard is 0) and this is important.
no undersampling. (otherwise you cant choose upsampling)
If you still get broken lines or geometry missing then change AA "Thickness" size from 1 to 2 or 3 pixels.
Tolerance 0.1 (like in lw) or smaller like 0.06
I have newly started to use this mode and this AA mode gives me same or better AA than Lightwaves standard adaptive Low, but is very fast.
