Another doodle
- phile_forum
Another doodle
Full-screen AA & lots of settings turned up, so it took 2h on my Q6600. Mitchell filter to soften the image, then sharpened it a little in post.
- doodle_02.jpg (279.91 KiB) Viewed 10574 times
- phile_forum
What is it? Well... it's a, you know, thingummy. A wotisit. Maybe even a doobrey. I just like shiny things
Phil
Phil
- phile_forum
And, for my next trick:
- doodle_03.jpg (262.96 KiB) Viewed 10504 times
Played with it too. There was an article on newtek forums about modeling or texturing perforated metal a few days before you posted your doodle.
Phil, i hope i'm not ruining your trick. Just wanted others to see the post too. Vfxwizard found a really nice trick there. Useful for more purposes. Check it out.
http://www.newtek.com/forums/showthread.php?t=75463
- phile_forum
Heh. Rumbled!
Yes, that's where I got the idea. It's a very, very clever bit of modelling. When I next get some free time, I intend to see how much further I can take the idea.
Posting here was really just to show off Kray though!
Phil
Phil
- phile_forum
1000x1000mlon wrote:whats the orig res for the render?
2 hours for a q6600 seems rather long.
It took ages because I turned up a lot of settings to eliminate noise (quasi random FSAA with lots of samples, for instance). There's also a lot of transparency/refraction going on, which will slow any renderer down I think. It could probably be done a lot faster but I wasn't going for optimisation.
Phil
