Stronger shadows?
walfridson
Stronger shadows?
Post by walfridson »
Hey testing a cgtalk scene. It's a wip so don't mind the quality.
Got one version with a area light in the window.
In another version I light up the room with skylight. This lights up the room but produce very weak shadows. Specially the sphere on the left on the wall. Any ideas how to make them stronger and still use skylight?
Photon multiplier is 1.0, 12 bounces. Both scenes has a sun light.
edit
lumopoly version:
skype walfridson
NiGMa
Post by NiGMa »
Yes, i have an idea!
Turn off CI (Cached Irradiance) and you should see the shadows.
otherwise if you want the speed of CI, keep lowering Spatial tolerance and Distance Min until you see the shadows. And I mean low, I've been using Spatial tolerance = 0.01 and Distance Min = 5.0% although I've never seen anyone on these forums go that low. I just need to have as many small shadows as possible! =)
acidarrow
Post by acidarrow »
Do you have a link for the scene? Also what settings are you using right now?
NiGMa
Post by NiGMa »
yes, link to scene please.
walfridson
sure!
attached pic shows CI with spatial tolerance at 0.01, little bit better...
lighttest.rar
(585.52 KiB) Downloaded 520 times
skype walfridson
erwin zwart
Post by erwin zwart »
after you gave me a link yesterday in IRC, I came up with this one. Your scene with one spotlight (converted to area) and skylight plugin.
NiGMa
Post by NiGMa »
how come half you guys have OB3.5? wheres mine?
It is IB3.5 (internal beta).
NiGMa
Post by NiGMa »
I guess I dont want to be dealing with bugs so much. So I wont ask again. lol. I'll just try my best to let you know about all the bugs in th OB's =)
tiktane358
Post by tiktane358 »
NiGMa, I have photoshop !!!! What version of Kray you want to be written on my tests ? :wink:
walfridson
here's my result after some tweaking. hard to get nice result and low render times when pushing edge absolute :).. in this one i'm using 0.07
by the way if silvermannen, jure or any other betatester is reading.
when using catmull i get black lines:
using quadric gives me a whole black image after antibanding.
skype walfridson
Captain Obvious
Post by Captain Obvious »
Catmull Rom is an edge sharpening filter, so you usually get lines like that around high-contrast areas.
Post by silverlw »
And another version with caustics enabled.
Luminosity modell "Automatic" enabled so the brighter luminous object gets rendered as "direct".
I like the precision of direct mode.
Walfridsson Lighttest.rar
(600.99 KiB) Downloaded 474 times
