luminous polys without emitting light
_mats_
Post by _mats_ »
Hi -
I was wondering if there is a way to have polygons that are "luminous" but do not emit light?
for instance if I have some ceiling spotlights and I want them to be pure white, but not be computed as a lumi poly by Kray, (since I will be using an actual spotlight or point light under it)
any ideas?
thanks
Matt -
adk
Post by adk »
... drive diffuse above 100%
(not sure if it might possibly mess with other aspects of your scene tho - someone else might know if it does)
Top row are luminous polys@500%
Bottom row are diffuse polys@500%
diffuse>100%
diffuse>100%
_mats_
Post by _mats_ »
excellent tip
Thanks ! glad to see there is way to do this
loving Kray here
Matt -
adk
Post by adk »
no probs ... there are a lot of things in LW that go above 100% .... and quite a few that go below 0 for that matter. Always worth knowing.
Pavlov
Post by Pavlov »
You can also put them at 99% and set luminosty threeshold at 100%, so all lumipolys under 100% will be computed in indirect mode. It's fast and this gives you a "halo" around them since they emit light in irradiance phase, but nothing more since they wont fire FG rays.
Paolo
adk
Post by adk »
Great tip Pavlov :) many thanks
_mats_
Post by _mats_ »
Yes, excellent tip Pavlov.
Both tips work great, I suppose for slightly different circumstances.
Thanks to you both !
Matt-
