What the heck is QMC?
obo
Post by obo »
Hi.
What is qmc?
Re: What the heck is QMC?
obo wrote:Hi.
What is qmc?
QMC = a brute force GI that samples every pixel.
Quasi Monte Carlo.
So if we have in Kray PM+QMC it means:
1. first phase is shooting interpolated photons and create map on which is based QMC
2. second phase is calculating GI samples as brute force (QMC)
This method is very close Path Tracing accuracy but much faster.
thomas
Post by thomas »
To put it simply:
With QMC, a number if rays is shot from every pixel to calculate the shadow and global illumination for that pixel. It is a "brute force" method because the process is not smart, but very simple: the more rays you shoot for every pixel the better the calculation becomes, and the less noise you have.
So with QMC it is:
general visual quality: accurate (with detailed shadows) but noisy if set at low quality
pro: perfectly exact result given enough rays fired
contra: no optimisations. Rendering for twice as long will make your result twice as accurate - no more, no less.
Photon mapping and Final Gathering methods are much smarter, will interpolate between results with smooth gradients, and generally do a lot of pre-processing or scene analysis to see where more rays need to fired, or more smoothing can be done between fewer data point.
So with PM it is:
general visual quality: smooth and noise-free, but lacking shadow or GI detail (and sometimes "splotchy")if set at low quality
pro: faster than QMC, and quickly noise free for large surfaces like walls and floors in Architecture Visualisation
contra: less shadow detail because some stuff is smoothed out. The faster the render, the more details are lost.
I hope that helps out a bit.
If you are going to make top-quality work I would suggest using QMC for now, if you have the time. The biggest advantage to interpolated methods is speed.
Cheers,
Thomas
obo
Post by obo »
Thank you.
But can someone post some setup? Just basics.
Here basic scene with PM+QMC with good universal settings:
GI_test.7z
(2.74 MiB) Downloaded 11167 times
obo
Post by obo »
Thanks a lot Janusz!
I'have only Kray 2.61 demo, I'm playing with it just for fun, but my time was above 12 minutes. Is that because demo or my pc? I have i56600K and 16GB Ram 2400
obo wrote:Thanks a lot Janusz!
Here is Cinebch R15:
http://http.maxon.net/pub/benchmarks/CI ... 15.038.zip
Download, unpack,test your CPU and post here your score.
obo
Post by obo »
606
obo wrote:606
4700 here, so your times render is correct.
obo
Post by obo »
Ok. Thank you very much.
promity
Post by promity »
Strange thing - first time render was about 2 minutes, then i close all background programms and ta-da - 9 minutes, then i press render again - white render window for 5 seconds and crash.
vgabex
Post by vgabex »
Janusz Biela wrote:
obo wrote:606
Janusz, is your config a dual E5-2697 v4?
I'm planning to step up from my 1700 cinebench point (i7-5960X @ 4.4) to a higher level.
Can you please help with your exact pcu, mobo and ram specs?
Thank you!
obo
Post by obo »
I have a scene with these presets and it renders great, but than when i change lem luminoisty and hit render, result is the same. Why is that happening?
vgabex wrote:
Janusz Biela wrote:
obo wrote:606
Thank you!
This what we have in office:
obo wrote:I have a scene with these presets and it renders great, but than when i change lem luminoisty and hit render, result is the same. Why is that happening?
Ah I see now: inside are two lws (old and new one)
Use this one:
room.lws
(38.47 KiB) Downloaded 11001 times
LEM panel is hidden from ray-tracing (only gives light, similar behavior like Area Light).
To do that you must put LEM to separate layer and setup unseen flags in this way:
and enable in Kray: Unseen by Rays...
