Pinterest style.
artattak
Pinterest style.
Post by artattak »
Pinterest style.
Visualization in a vertical orientation.
Asticles
Re: Pinterest style.
Post by Asticles »
Amazing works!
A pity the noisy screen of the first image, but impressive images!
He use only QMC rendering like me.
This is pretty easy now:
kray_settings.KGcfg
(1.06 KiB) Downloaded 1448 times
...and good hardware, minimum 2700 pts in Cinebench R15
artattak
Post by artattak »
I agree with Janusz.
These settings eliminate a lot of errors that occur in the FG.
The ideal global shadows without errors. There are no problems with the contact shadows addition lumi panels with high luminosity values do not cause errors.
Important hopefully eliminate errors in reflection to give accurisity limit of 10-20%.
Unfortunately, rendering to these settings requires a powerful computer.
Average time renderu on a computer with a score of 4700 pts in Cinebench R15 continues at a resolution of 2600x1733 px 10-15min.
The fastest i7 processors are the result of 1600 pts which equals approximately one hour.
Kray is very flexible and can render previews even i7 in 1-2 minutes.
I encourage you to experiment.
Everything comes easily sucks.
thomas
Post by thomas »
Amazing work, as always!
Also, as you know, I always give one point of critique, no matter how good the work is, to advance even more! So here it is:
The iMac immediately catches my attention, telling me that the image is CGI, because:
1) The base of the iMac should be matte aluminium, not chrome
2) The Apple logo is missing
3) The black screen has very sharp reflections in real life, not blurred.
I'm sure you are aware of this yourself, and it's probably more because of time constraints. Either way, congratulations on the amazing work!
thomas
Post by thomas »
Hi Janusz,
Are these the QuickLWF and Tonemap Blending parameters you suggest for all images?
Best,
Thomas
Generally it should be ONLY LWF gamma in renders. But without real time post processing (especially without clip white/dark, contrast, exposure, burn out) this is difficult.
I use this for all renders.
If you want try to use ONLY LWF gamma, setup this
Both gamma must be the same. You can change gamma for example: 2.2.
