benchmark QMC
benchmark QMC
This is scene to run K3 and play with VPR. Please do not take it as benchmark in serious case.
In scene you can notice differences between K2/K3 in the following cases:
- Global Illumination: K3 has new engine, transport of photons is much faster and more accurate with special detection for corner/edges
- QMC sampling has also some differences because GI sample are based on the information from Photon Map
- Setting Area Light for K2 in this scene (You have both K2 and K3) is ultimate extreme and if you will put same for normal interior with a couple light sources + surfaces + Nodes...simply you will never finish render.
How to use.
1. Open scene
2. Run K3VPR by Kray3CmdPvRatracing, you should see:
It is render QMC without Photon Map.
3. Press Kray3CmdBuildGI Kray will start fill up scene with photons in PhotonMap system (photons from light sources)
You can now:
- change camera
- move/rotate camera
- change resolution (for example by multiplier)
- you can change render system to Precompute, Global or Ambient Occlusion
- you can play with Tone Mapping
Scene:
benchmark_QMC_PhotonMap.7z
(4.75 MiB) Downloaded 871 times
Re: benchmark QMC
If you want render in full mode:
Before procedures from above press ctrl+q Master Plugin, choose Kray3Override and disable it.
