Simple box test
Simple box test
Scene is simple as simple can be box and sphere but for testing with many configurations is perfect.
Corona pure Path Tracing (no idea how many bounce lights):
Corona UHD (cached):
K3 Path Tracing 10 bounce lights (actually it does`t matter what engine...PT is PT):
K3 (cached Photon Map):
Reference link: https://coronarenderer.freshdesk.com/su ... is-enough-
Scene for Lightwave (only K3):
GI_test_Corona.zip
(760.49 KiB) Downloaded 1374 times
Scene is in LightMap mode (standard, bad photon positions) PhotonMap mode not working yet in K3 with Physky2.
thibault
Re: Simple box test
Post by thibault »
Hi and thanks for the test.
How are you doing for installing PhysicSky ?
Thanks
Re: Simple box test
thibault wrote:Hi and thanks for the test.
Thanks
I will explain everything when OB3 will be ready (G. wrote: is left only random VPR Crash)
But is very simple:
ctrl+q (LW Master Plugin) and you select from plugins Kray3PhySky.
For setting light position simply switch to small window preview in KrayVPR in Path Tracing Mode or just pure Ray Tracing.
Re: Simple box test
Thanks from artzgodka for these tests in native Lightwave:
promity
Re: Simple box test
Post by promity »
E5-2696 v2 - it's ES? Wich revision?
Re: Simple box test
promity wrote:E5-2696 v2 - it's ES? Wich revision?
I know only this is a bit overclocked Dual Xeon with score in Cinebench R15 around 3000 pts.
