maximum render
				jean-claude
maximum render
Hello. I have a rendering problem. I made a record with Kray 30000x18000 and the image is all yellow. There's a maximum with t he Kray?
Re: maximum render
Should be not (this is up to Lightwave).jean-claude wrote:Hello. I have a rendering problem. I made a record with Kray 30000x18000 and the image is all yellow. There's a maximum with t he Kray?
Please render this scene in raytracing, without AA, reflection/blur, lights in half of this resolution.
I will check here this resolution. Also write here what LW and Kray version.
				jean-claude
Re: maximum render
I use Mac LW 2015 and 2.2 Kray
I did the same rendering to 10,000 and it works
I Kray connnais not enough to handle everything
Re: maximum render
Thanks. I checked here on Windows + LW2015 + K2.58 and seems be ok.
If you can catch this problem with small scene (can be anything, single box) please send me via PM.
For LW2015 is special Kray version, if you use K2.2 which is quite old then can be situation when is something wrong on the SDK level. It should be the newest Kray for LW11.6 (which is also for LW2015).
