Does anyone have any free LW plugin or script that splits polygons into different layers per polygon surface.
I searched and couldn't find any.
Thanks
Chris
SURFACE SPLIT
Re: SURFACE SPLIT
Never mind , I made a small lscript that does exactly that (based on an older one by Al Street):
Just put all the mesh on the first empty layer of a new object and run the script , it will split the polygons into layers per surface , and rename the layers with surface name.
- split_surfaces.zip
- (404 Bytes) Downloaded 435 times
Re: SURFACE SPLIT
ah...big thanks for tha,t is PERFECT! I always searched solution for fast editing after importing from max! Thanks again!!
Re: SURFACE SPLIT
yes, very good... thanks mister
Re: SURFACE SPLIT
Chris can share your script on other lw forum?
can you write your name or web site so share it?
fantastic script!!!
fantastic script!!!
Re: SURFACE SPLIT
I am glad you found it useful;
Free free to share it , but actually most of the script existed already ,
I just put the part that renames the new layers with the surface name.
Re: SURFACE SPLIT
It's been a long time, but anybody knows if this script still works with the recent lw release? I'm on 2015.2 and it does nothing now...
