help please
CROMO3D
help please
Post by CROMO3D »
hi im a new user of kray, i've two problem
1)my final renderind dont show me all the object in my scene, kray dont render all my object, is there some reason?
2) i need to create a neon light, i set the luminosity to 150 but kray don't show me the brightness
can someone help me? thanx!
ps: i used kray 10033
:D
Could be several different reasons to your problems... Most likely you're scene is setup in unusual way...
There are lot's of posts in this forum that can help you, just browse it a bit...
CROMO3D
Post by CROMO3D »
jure wrote:Could be several different reasons to your problems... Most likely you're scene is setup in unusual way...
hey, i've tried a lots of post about my problem of neon light... thanx...but i have tried nothing about the disappear fo my object in the final render.. please can you help me? :oops:
What kind of object is it? Can you post example LW vs. Kray render for example?
CROMO3D
Post by CROMO3D »
hi, thanx for the patience :)
as you can see in the second pic there are more objects. im just realize that i have the same problem in Fprime, what do you think about? thanx
Hmm I'm not sure what this could be. Check your scene flags, object properties settings or post your scene here so we can check it...
CROMO3D
Post by CROMO3D »
hi Jure, thanx again fot your reply, i solved my problem, i've paste my object in another layer is there some kind of texture that kray don't support? i don't know way the locker in the pic is so dark. what do you tink about?
thanx
pixym
Post by pixym »
Always be sure your objects are at last displayed in wireframe mode.
Objects in Bounding box are not rendered...
Eddy MARILLAT
PIXYM
CROMO3D
Post by CROMO3D »
pixym wrote:Always be sure your objects are at last displayed in wireframe mode.
OK, precious advice, thanx :D and about the texture? do you have some advice? :)
thanx
pixym
Post by pixym »
unfortunetly, no, I am also a new user ;)
Eddy MARILLAT
PIXYM
CROMO3D wrote:hi Jure, thanx again fot your reply, i solved my problem, i've paste my object in another layer is there some kind of texture that kray don't support? i don't know way the locker in the pic is so dark. what do you tink about?
thanx
Probably you have dark image texture and low diffuse... Try raising that. The locker should probably have a bit of reflection also since it's metal..
CROMO3D
Post by CROMO3D »
hi, thanx, i solved my problem it was the polygon below :)
anyway, do you have some good advice to refine my pic? what for you is no good?i'v have set kray with
diffuse model : photo mapping
luminosity: compute as direct
area lights: compute with luminosity
gamma 2.2
i not used the other tab
thanx :)
