Architectural Visualisation | Movie
Steel
Post by Steel »
Movie was realized with Lightwave,Kray and Post in After Effects.
Thx for watching :)
[youtube]IpS7Etz_3NM[/youtube]
Re: Architectural Visualisation | Movie
Good job! Next time Path Tracing :wink:
Finally somebody make good camera track (Not crazy walking/flaying through scene....)
Time render per frame?
Steel
Post by Steel »
Thanks Janusz :) .
Rendertime between about 10 and up to 30minutes per frame on very fast workstation.
Maybe next time i try to take a look at Path Tracing. :oops:
Steel wrote:Thanks Janusz :) .
It is good time. Soon I will post Path Tracing setup for exteriors (Because this is the best system in my opinion for exteriors in Kray) It is very fast, no problems (You do not need photons for this) , no flickering, no splotches, you can move everything what you want in scene, you can change power of lights , render start immediately, you can stop and resume , etc.
The time for Path Tracing should be for your scene between 10-30 min...so the same, but read above all positive things ....
