A recent project - Kray + PS post
						Tender Render
Re: Tender Render
SWEET!!! Would you share your water surface?
Re: Tender Render
O yea!! Can you tell something more about it?
						Re: Tender Render
Currently in build project - More info can be found here - http://www.pascoeinternational.com/tenders/sl_range
Using Lightwave and Kray for all previz and design development work - once design is settled upon we take into rhino for production.
We also use Rhino and Vray - Would be nice if we could port Kray. actually scratch that, ill just settle for Kray3
Water is sadly an image plate behind, though I set the challenge for someone to create that type of water and share if they're feeling like a challenge.
Re: Tender Render
Kray SDK is ready. Is just matter if somebody ii enough skilled to do it
About render: is not big challenge to render this model...the challenge is in surfacing and you did it in correct way (also the quality of AA and blur). Today You can render everything by Kray because is not different between V-ray, Maxwell or everything else ..the only one problem is with surfacing (Nodes) and artistic skill.
The best renders has very complex surfacing and is really doesn`t matter what kind of render engine you use
Again, really good renders!
				universalpenman
Re: Tender Render
freaking amazing dude, love it, pls bigger images, wallpaper perhaps?  ,
,Re: Tender Render
Favolous design and very very good render...
