I have terrible problem, while baking the calculations for each consecutive frame are taking 2x longer , while CPU usage is getting lower and lower. After 50-100 frames each new frame is taking about forever.
Animation option is on. Its happening for both Save and Add options.
							baking GI, each frame 2x slower, 2x less cpu usage
Cheers
Tomek
GarageFarm.NET
We are the cheapest render farm! 260 nodes and still growing!
Skype: garage.farm
						Tomek
GarageFarm.NET
Skype: garage.farm
Re: baking GI, each frame 2x slower, 2x less cpu usage
soth3d wrote:Hi,
I noticed this last time (even when I BAKE every 20th frame)...not all the time. This is very hard to find bug, because is random. In K3.0 perhaps will disappear. Sorry but I suggest save only Photon Map (after start animation Kray shoot photons for whole scene and track camera for it, then start automatically first frame of animation and just press cancel when start second frame. First frame must be done to save this file so remember setup no AA and blur. After when You have Photon Map file - very small file - choice in Kray LOAD. All frame must render with all passes - THIS IS NOT BAKE!)
Maybe method is a bit slower ...but is not:
- You do not waste time for BAKE
- You can stop and continue whatever You want
- You can use this file for another computer and render another range of frames
- You can use this file for network rendering without any problems
- If You will get crash by accidents You can continue without worries
- whole important and dangerus procedure with animation will take maximum ~1 min
Janusz,
I'm currently also having the same issue, I bake every 20 frame. After 60 frames, the next frame need few hours to bake.
Regarding on your Save Photon, can you kindly guide us with Screen shot of the setting please?
I currently in progress of final rendering with full furniture.
here small tutorial and I hope now is clear. Of course in K3.0 will be only one button for that
[youtube]zgDDVICcRQ0[/youtube]
Hope you have voice over in future tutorials. Even if the voice over is not perfect english is fine.
jnom wrote:Hope you have voice over in future tutorials. Even if the voice over is not perfect english is fine.
Yes this will be for sure
 and tutorials will be done in professional software which is made for that
 and tutorials will be done in professional software which is made for that   . This is just funny test of Youtube...
