WIP ...
rosstheboss
WIP ...
Post by rosstheboss »
Somthing new that im working on now. i using only sunlight from kray anf lumi panels at windows in order to save some time. some advices about how to save more time are welcomes. (i want to animate this later)
Re: WIP ...
Looks good! If I can advice:
1. good mapping of textures is needed (I see cubic mapping on sofa) + better surfaces (Nodes, Nodes and Nodes :) )
2. You need better (stronger) setup of Final Gathering . I know is longer but under lemons are bright (floating effect) so if will be more stuff there this whole table part will looks artificial :)
3. Carpet need fix...will give You my new setup of that (is done by LW instances, if You want another shape of carpet just copy LW Instance setup to new object and increase/decrease amount of fur . If You want more flat effect go to Instance setup and increase/decrease procedural texture layer opacity )
4. Curtains bad....but I know : they are the hardest to render :D this material is SCIENCE....
carpet.rar
(3.44 MiB) Downloaded 350 times
white_curtain.srf
(50.4 KiB) Downloaded 332 times
