Vray Shader in Kray
medzo
Vray Shader in Kray
Post by medzo »
Hi
I made a shader node that (hopefully) would resemble vray material in studio max. I am not sure that translucency is set up correctly, but mixer nodes for reflection and reflection blurrings should work like in vray (i think). Also reflection shader is just for metals.
I am sharing it with you, so maybe we can improve it together.
_MATERIAL.srf
(53.12 KiB) Downloaded 377 times
medzo
Re: Vray Shader in Kray
Post by medzo »
Just found out that i made a mistake. Here is the correct version.
Please test it, so we can make a shader that would work.
_MATERIAL v2.srf
(53.13 KiB) Downloaded 355 times
Thank You! Will test it.....
