Smooth procedurals
Smooth procedurals
Hi
Does anyone have good settings for procedurals that would produce smooth bump. I am attaching the image bump is hybrid-multifractal procedural node... as i found, basically all lightwaves procedurals produce this weird ''hi-peak'' or sharp transitions ... i cant set it to be smooth. Anyone knows how to make procedurals that would look smooth?
Re: Smooth procedurals
There is it. You can control bump and size (Node, Normal smooth)
Check all because I do not remember in which one is good smooth...
- glass_windows.srf
- (47.9 KiB) Downloaded 491 times
- windows_plastic.srf
- (47.79 KiB) Downloaded 462 times
- plastic_dark.srf
- (48.92 KiB) Downloaded 484 times
- Ceramic_white.srf
- (48.95 KiB) Downloaded 454 times
- Cabinet_white.srf
- (48.6 KiB) Downloaded 483 times
Thanks Janusz!!! Now I wont have to use image maps! Funny... fractal noise doesnt even exist in 3d textures node...
Thanks, I stoppped looking for an answer a while ago
Sorry I do not understand ...You have everything in those nodes which I uploaded.medzo wrote:Thanks Janusz!!! Now I wont have to use image maps! Funny... fractal noise doesnt even exist in 3d textures node...
I think he wants to ask, like me, where can we find the plug-in name TextureHandler?
No, no... i got it all:) thanks again!
Yes i know DP plug-in but when i load for example cabinet-white, it says that "No plug-in of type TextureHandler found with name Flow Noise"..! I don't understand
It means your plugins haven't loaded properly. Try to rebuild your configs...Alek6 wrote:Yes i know DP plug-in but when i load for example cabinet-white, it says that "No plug-in of type TextureHandler found with name Flow Noise"..! I don't understand
