Hi kray friends.
I've a little question...  have you ever try RenderQ and Kray?
I've set 4 scenes, in Kray in the Misc tab i've set "close preview on finish" on every scene,buffer export activated, different name for every file saved . In Lw the frame range is ok for all scene.
In a new session of the layout i start render Q and make a list of the four scenes.
The render starts, but RenderQ render only the first 2 scene on the list! no matter which ones. Just the first two..
Any advice?
Thanks a lot.
Cheers
						Kray and RenderQ
Re: Kray and RenderQ
The problem is LightWave does not send 'LWEVNT_NOTIFY_RENDER_COMPLETE' notification to Lscripts when using external renderers. Actually it sends this notification only once (that is why only first 2 scenes renders). Its the same for any external renderer, not only Kray (I've tested it with DarkRenderer - LW SDK renderer sample). Unfortunately problem isn't Kray nor RenderQ script. It must be fixed in Layout core.
Thank you Jure!Very esaustive answer, now i've understand.
At least it wasn't my fault
