Hi there,
How could I change the matte color of Surface ID / Object ID buffer in Kray render setup?
Thanks,
Azmen
						Change the matte color of ID buffer output
				azman_821009
Re: Change the matte color of ID buffer output
azman_821009 wrote:Hi there,
Thanks,
Azmen
Hey!
I do not think so i possible. Maybe G. has in code some switches which never shared.
Why would you do that?
				azman_821009
What I experienced was that some of the output colors are very similar to each other. This will affect me during the selection where all the objects with similar colors will be selected which means I have to go through each similar colored objects to ensure that objects I do not want to be selected are not selected.khan973 wrote:Why would you do that?
I think you can't change an object's Color Id but maybe you can change its ID. I don't know how LW defines an objects ID. It might be a good start. If you can mofify the parameters that affect object's ID (color? size? layer?) maybe t can lead to an other ID / Color.
