splotch in corner...
why in my scene there are the splotch in corner??
see the image and object please :mrgreen:
model in lw simply cube....medium setup :oops:
thank's
1.lws
(25.22 KiB) Downloaded 342 times
testa.lwo
(3.42 KiB) Downloaded 332 times
Re: splotch in corner...
Looks like photon leaks. Try increasing N number in photons tab.
Btw. in cases with artificial light photon map instead of lightmap works better.
...lightmap works better...it's true!!! this is the render!!! :mrgreen:
this is a fast render (3 min) witout lw lighting - only emitter in ceiling and down mirror.
little post.
lightmap render.
when i use only light emitter witout lw light i'ven't definied shadows.
how can see it? the lighting is perfect but with less shadows it's a not real render!! :cry:
jdomingo
Post by jdomingo »
jure wrote:Btw. in cases with artificial light photon map instead of lightmap works better.
sometimes when using photonmap instead of lightmap there are some black spot on some areas. some are big some are small.
is there a bug on using photonmap?
probably it's just the way photon map works.. It usualy needs more photons than lightmap.
