Satch
Re: Satch
Very good!
...but can You show more info? wire, light.. to see how much photoshop you used?
Re: Satch
Hi guys , thank you for the feedback, i was a little bit busy and completly forgot the posting here in kray forum ! i use to spread every finished piece in several 3d stuff forum and can't believe missed this one, expecially for a feedback junky like me !
Guys You could check out other renders done with VPR and F9 here :
http://latifghouali.blogspot.com/
. the main reason of using kray was for the speed, the image is renederd at 4k and took about 20h to render on my laptop elitebook i7 520m 2.4ghz / 8 ram gigs, but i bellieve it could take less than half with meduim antialising setup ( i set up it to hight ). the radiosity coupled with simple skin shader always increase drastically the render time.
Janusz Biela - thank you , will post zbrush grabs, wires, everything soon, used photoshop to composit passes ( direct, indirect, reflcetion ...) , the hair pass is done using f9. and correct some weird areas visible in highrez render, and to add grains, chromatic aberations, starglow flares .
Medzo - thanks, its always great to receive the wow effect comment, especially when you give lot of effort on a piece.
Jure - thanks, nobody hates satriani !!!
Pantarei - yes the bridge isnt a perfect copy of the original and you're the second person who mention it !
Thanks again.
Thanks again.
