Shade problem in Kray rendering.
azman_821009
Post by azman_821009 »
Hey guys,
I just tried to make a growing trees and render in kray used instance. After done the rendering, I've seen the trees have a problem with the shade. Here is the sample http://www.youtube.com/watch?v=NlRrbBGjuRI
Need some help please.
Thanks.
Azmen
Re: Shade problem in Kray rendering.
Try doing it in reverse. Start with big tree and reduce it.
azman_821009
jure wrote:Try doing it in reverse. Start with big tree and reduce it.
Hi Jure. It's still same.
Could you post the scene?
azman_821009
Here is the scene..
test_point_Trees.lws
(23.95 KiB) Downloaded 342 times
Thanks.
You did not post your objects but scene looks fine. You would want to use some kind of caching to prevent flicker though.
azman_821009
jure wrote:You did not post your objects but scene looks fine. You would want to use some kind of caching to prevent flicker though.
Sorry about that. The objects are huge so I don't think so that I be able to send it thru here. Maybe just only point object. What do you mean by caching? Caching Irradiance?
i mean using shared GI or time interpolation mode.
azman_821009
OK. I tried a Shared GI mode but it still the same.
Please post your scene with objects included then.
azman_821009
jure wrote:Please post your scene with objects included then.
The file size is about 22mb (zip file), so how can I send it to you? I was trying to send it but the maximum for upload is just only 2mb.
Any idea?
I only need the tree and the scene. That shouldn't be that big..?
azman_821009
jure wrote:I only need the tree and the scene. That shouldn't be that big..?
Yes, I knew it but the tree size is 40.8mb (before compress and it's original file).
could u replace it with more simpler object and see if u get same issue?
azman_821009
I replaced just a simple box and the result was good.
