Hey guys,
How can I make the object as lighting use a kray plugin? For example the street lamp.
Thanks.
Azmen
						Objects as Lighting
				azman_821009
				azman_821009
Re: Objects as Lighting
Yes, I did that before. Used it on the street lamp but the street still darker. It should be lighter.
Luminosity as raytracing shader in Kray (just for effect) + Area lights as real source of lightazman_821009 wrote:Yes, I did that before. Used it on the street lamp but the street still darker. It should be lighter.
well use more luminosity.azman_821009 wrote:Yes, I did that before. Used it on the street lamp but the street still darker. It should be lighter.
				azman_821009
Thanks for your tips Jure & Janusz. I will try it first. Planning to make a next animation with night scene.
				azman_821009
Forgot 1 more thing. Volumetric in Physical Sky just work only for light or it's work to for luminosity objects?
Only for physical sky.azman_821009 wrote:Forgot 1 more thing. Volumetric in Physical Sky just work only for light or it's work to for luminosity objects?
