Hi Jure,
I've a problem with point. I use spray point for making instance grass.
If i return in modeler for modify point (sup and move), the render instance don't works. I must redefine my spray point in modeler in new layer and after, it's Ok!
Any ideas ?
Thank in advance
						PB with spray point
Re: PB with spray point
Maybe you did it in new layer? or you made mistakes with layers...thibault wrote:Hi Jure,
Any ideas ?
Thank in advance
Thanks Janusz,
I found. When i modify the points in modeler, after, in layout,  i must sup plug KrayInstance in property object and call again.
Thanks again
						I found.
  When i modify the points in modeler, after, in layout,  i must sup plug KrayInstance in property object and call again.Thanks again
This action should not happen....something is wrong in communication between LW/Modelere (i know , information about amount of instances is not update in frames KrayInstance plugin, but this not affect in render)thibault wrote:Thanks Janusz,
I found.When i modify the points in modeler, after, in layout, i must sup plug KrayInstance in property object and call again.
Thanks again
