Modern house
Modern house
My WiP. I just start my old scene again....I will play with some ideas. Scene is empty with horizons trees as texture.
Re: Modern house
Wooow! very nice grass and texturing!
Re: Modern house
Utterly brilliant! The texturing is amazing. The slight glossiness of the painted steel is really subtle!
Re: Modern house
light texture grass amazing
A teacher for all !
A teacher for all !
Re: Modern house
I like the well balanced light and the way the light falls on the grass.
Superb work!
Superb work!
Re: Modern house
later I will share my grass on forum. I have some ideas how make it more realistic.BarryV wrote:I like the well balanced light and the way the light falls on the grass.
Superb work!
Re: Modern house
Very realistic!
Do you use a panorama surrounding as enviroment?
Re: Modern house
Now are real trees. previous renders has panorama with clip map.BarryV wrote:Very realistic!
Re: Modern house
Althought I think you ruin your renders with the strong color Halos, your renders are amazing!
Would worth showing the Vray community what's possible and also post on NT forums!
Re: Modern house
This looks like slightly tweaked Farnsworth House.....great renders.
Re: Modern house
I know is a bit candy (I like it!...I am bored by renders with poor colour, of coarse I like B/W also.)khan973 wrote:Althought I think you ruin your renders with the strong color Halos, your renders are amazing!
When quality will be enough I will show ... but now still I want some additional in Kray which will increse quality (displacement, new GI, update tonemping, instance from textures...)
Re: Modern house
I don't dislike candy renders but I think it needs a little more work to do it better. You have hight expectations on your own work which pushes things and people further!!! you just should do the same with your PS :p
In Fact It's just the big coloured halos that look weird and too opaque and saturated (believe me I'm a graphic designer :p)
i want some displacements too!!! and better instances, but we have to be proud, there are a lot of better renders over here thanks to you and some others!
We just have to show that there are other solutions than Max - Vray!!! And good ones!
Re: Modern house
Thanks!khan973 wrote:I don't dislike candy renders but I think it needs a little more work to do it better. You have hight expectations on your own work which pushes things and people further!!! you just should do the same with your PS :p
it is very hard make good render (must be good composition of textures, objects, light, postproces...so sometimes I experiment)
Yes, I agree: displacement and new instance
Re: Modern house
When you say such things, I feel so far behind!
I can't imagine hitting Kray's boundaries!
What do you mean by correction for GI engine?
You're right about experimentation. There are a lot of good examples of photographers doing great job at retouching and creating amazing unique looks.
