The manual says :
lwo2rayslimit
Can prevent problems with LW carpaint material. lwo2rayslimit 1,0.9; works as follows: rays above recursion level 1 of node evaluation will be fired only in 90% (0.9) tries. It prevents for very depth recursion (which can happend with car paint material)
And my question is : is it useful only with carpaint, or should it be used with others like conductor?
						About lwo2rayslimit
Re: About lwo2rayslimit
Yes it can be useful with other nodes too. If you fins photon shooting phase taking very long or hanging then try this command.brownie wrote:The manual says :
lwo2rayslimit
