hi
does anyone knows how to set up a walktrhough that pans around 360 horizontal and 180 vertical as well? or any cheap program to do that? i wanted to be able to pan around while i am walking through let's say at the corridor walkign toward another room and i can pan around at the same time. thanks for your sggestions
						walking thru and panning around
Re: walking thru and panning around
I Know  but its hard work
 but its hard work
1 Cheap opcions:
Unity3d indie edition its works fine and free. Only the pro version options are trial.
GameCore Indie edition now is free too. And works lwo directly
2 pay option:
Quest 3d is good but requires adaptation
Or Do you want a virtual tour with panoramas?
						 but its hard work
 but its hard work1 Cheap opcions:
2 pay option:
opm, i am assuming that the unity3d and gamecore and quest 3d required some programming knowledge....mmmmm my brain is not capable of doing some programming  . i would prefer the 3rd option, virtual tour with panorama, any suggeston? thanks
 . i would prefer the 3rd option, virtual tour with panorama, any suggeston? thanksRe: walking thru and panning around
ok
Panorama option
1 expensive: 700€
Tourweaver pro from Easypano.
- Very simple to use
- Customizable menus. Sound effects etc...
- Export to flash an EXE!!!
2 cheap: 59€ each
Pano2VR and Object2VR from Gardengnomesoftware
- Very simple to use too.
- Export to flash
Take a look to the videotutorials
Its easy to make panoramas or VR objects in lightwave and with Kray
 Panorama option
1 expensive: 700€
2 cheap: 59€ each
- Export to flash
Yes Jure but jdomingo don´t want to program and Autopano Tour use krpano and this require scriptsjure wrote:there's also Autopanowhich is pretty cool...
- matt gorner
Free QuickTime VR Tutorial on Simply LightWave:
http://www.simplylightwave.com/movie_pa ... tut_id=521
I did not watch the tutorial but to create panorama in Kray just use "Spherical" camera mode in Kray General tab.
Does anyone know how to create an image with kray, as a single render,
to use in easypano without distortion?
