Hello,
i am trying to do some carpets. Here is one try, will post more soon.
Regards
Carpets
Re: Carpets
Look good
Btw
In next version of Instance we will receive better tool for that models. Density by textures, size by textures, variation by textures, etc
Btw
Re: Carpets
and the next thing i will try to do. Will post the results and compare with the original..
Re: Carpets
This is good example, scene is easy... but with our instance 1.0 fur will be difficult.joTTa wrote:and the next thing i will try to do. Will post the results and compare with the original..
- matt gorner
Re: Carpets
Pretty cool, although does look more like unkempt grass than carpet, love to know more about how you're doing these, instancing onviously, but setup etc.
Re: Carpets
it´s looks like grass because...it is grass with colour texture changed. Everything i use for this came from this forum. I use one tutorial for instancing and grass that i see here, i dont know exactly were. I have to try now with another shapes of hair and see what happens. I will check pictures of real carpets and try to make the carpets looks similar.matt gorner wrote:Pretty cool, although does look more like unkempt grass than carpet, love to know more about how you're doing these, instancing onviously, but setup etc.
Will post results.
Regards
Re: Carpets
Hey guys,
Thick carpet with real fibers attached in this post, strings of about 3mm. UV's just need a texture image of choice. (transparecy is for the ends of the fiber)
1st layer are instances, 2nd are the fibers. If it renders to long, just put subdivisions lower.
Greetzzz,
fabian
Greetzzz,
fabian
- carpet.lwo
- (896.85 KiB) Downloaded 325 times
