hi to all..
I've downloaded the 2.1 release and I've found that using an old 2.0 scene:
when I render the image,
during the process the tonemap is pretty ok, like the old 2.0 output
but when the process is finished
the image wash-out and all the white turn to gray
and the final saved image is different, with too big contrast
help!, is this a bug?
(I've checked all the tonemap plugins are off, and I'm using exponential 1.7/1.0 don't limit DR, HSV mode checked)
thanks!
							help, 2.1 tonemap bug?
				albertos2008
				albertos2008
Re: help, 2.1 tonemap bug?
hi jure...
I've solved.. but it's strange
now with "Limit DR after Tonemap"
everything it's ok..
before with the 2.0 release is works different...
thanks
(if you want I delete the post)
thanks
albertos2008 wrote:hi jure...
thanks
It's ok. Probably it was a bug before that is fixed now.
