 A bit long but hopefully very clear explanation.
When I press render sequence in kray to make an animation cache, timeline goes from 0 to 1, 0 to 2, 0 to 3 and so on until it cycles the end of the timeline. After that it then starts to render from frame 0. Once that 0 frame is done rendering and a tga,png file is autosaved in the hd, a cache is also created in the hd and kray continues to render frame 1,2, and so on.
Now my question is,
That cache created from after rendering frame 0, is that the cache for the whole sequence or only frame 0? Can I stop rendering frame 1,2,etc so that I can render all sequences in a network using that 0 frame cache file?
Right now I wait it out until kray renders all frames with no AA and it still takes time. Atleast 1 min per frame with no AA just to get the cache file at the end of the process. So 600 frames is 600mins. Since there's no way to just calculate cache radiosity I have done that way. Any suggestions?
