irradianceblurgamma
irradianceblurgamma
Is irradianceblurgamma tailer command still necessary for the current 2.0? Just been using it since 1.7.
						Re: irradianceblurgamma
It was just an experimental command. Imho you can use it if you want but i don't think you need it. It's better to use Path passes 1 or 2 on FG tab.
