AA settings quick description
Comments and questions about Kray user manual.
Grzegorz: edge absolute is a difference between pixels. if it is higher that than value both pixels are on the edge
Grzegorz: relative
Grzegorz: is a relation between pixels a/b
Grzegorz: where a is pixel1 brightbess b pixel2 brightness
Grzegorz: where absolute often misses edges in dark areas (not big brigthess difference) relative does not
Grzegorz: normal and z is normal and distance to camera edge detection
Grzegorz: so even if you have black square on black background
Grzegorz: it will be marked as edge if z is not zero
Grzegorz: what is nice is that z and normal can be detected to upsampled image
Grzegorz: i mean if you have 640x400 rendering and some details are sub pixel size thay can be skipped in edge detection. you can detect normal and z edges on twice as large image and dont miss those details this is what upsample is for
Grzegorz: thickness is a egde thickness in pixels
Grzegorz: you can also antialias pixels close to the edge
Grzegorz: overburn is to not detect edge on overburn areas
Playing with AA settings a bit and this setting produced quite nice rendering in reasonable time....
Please post your experience.
Post by silverlw »
Wow they seem to work very well! I want them in the onlinemanual NOW!
I switched to Grid2 or 3 instead of stochastic.
Another nice settings that seem to work in some scenes...
Post by silverlw »
"Relative" value makes me nut's.
Value 1.0 = 0 or no effekt at all.
Possitive affects something and negative effects something.
I would really like to have all this about AA explained in the online manual.
relative >1 will mark all pixels for AA. relative <1 is what you should use G. told me...
dalecampbelljr
Post by dalecampbelljr »
why is it that I can't see any of the image files that are attached on this forum?
Dale
dalecampbelljr wrote:why is it that I can't see any of the image files that are attached on this forum?
Dale
I'm not sure... You should be able to see attachments without a problem.
Pheidian
Post by Pheidian »
It's because either you're not registered user, or you're not logged in, I had same problem at first before I understood it :)
_mats_
Post by _mats_ »
wow I am not seeing ANY of those new options.. but I upgraded to OB 6.1
any ideas?
Haven1000
Post by Haven1000 »
_mats_ wrote:wow I am not seeing ANY of those new options.. but I upgraded to OB 6.1
any ideas?
That will be because it's a screen shot from OB1 or OB2 :wink:
_mats_
Post by _mats_ »
duhhh
sorry about that.. I thought I missed a secret update or something.
Note : MUST check post date before posting.
