FRESNEL
talats
FRESNEL
Post by talats »
Hi guys, could someone make a tutorial or explain how to use fresnel for opaque materials (non transparent materials) ? A tutorial explaining how to obtain the relationship between reflection and diffuseness?
To be sincer I am starting to be tired to set always incidence angle gradients. I really would like to do everything with a fresnel node, but, until now, I couldn't understaind how to work with that node and, more over, everything I found on the web always consider the relation between reflection and refraction (and it's good for transparent surfaces) but not how obtain the relation between reflection and diffuse.
Thanks a lot
Roberto
Re: FRESNEL
Try this. I use parametr 1.8 - 2.0 in fresnel + reflection map.
BASE DIFFUSE 0.9 for bright, 0.6 for very dark surfaces.
Preset.rar
(13.01 MiB) Downloaded 328 times
Re: FRESNEL
talats wrote:Hi guys, could someone make a tutorial or explain how to use fresnel for opaque materials (non transparent materials) ? A tutorial explaining how to obtain the relationship between reflection and diffuseness?
Thanks a lot
Roberto
For non transparent materials I haven't found any table that would list IOR for common materials. However you can try and download some vray or maxwell material presets and look what values they use... For metals it tends to be a high value... 10-20. Other materials have lower. Experiment and watch the world around you.
talats
Re: FRESNEL
Post by talats »
Thanks Janusz,
I am downloading it right now. I'll try and see what will happen.
Just in case, can I contact you in pvt if I have some quest on it?
Jure,
Unfortunately I don't have Maxwell and/or 3DS Max with Vray, so I am not able to compare nothing. And even if I had it, I wouldn't know where to go and check because I don't know how to use those programs.
Anyway, you are always in first line to help me, so thank you man.
Roberto
talats
Re: FRESNEL
Post by talats »
Hey Jhony, just apply those nodes to one surface of my scene (on the floor) using my orinal textures. It seems that it slow down the render. Is it possibile or i miss something?
Roberto
Re: FRESNEL
talats wrote:Hey Jhony, just apply those nodes to one surface of my scene (on the floor) using my orinal textures. It seems that it slow down the render. Is it possibile or i miss something?
Roberto
maybe becouse of fresnel (high reflection on 90 degree.....)
Re: FRESNEL
talats wrote:Thanks Janusz,
Jure,
Roberto
My Skype: johny_quick
