Matt objects
geo_n
Matt objects
Post by geo_n »
Are there any updates on supporting matt objects in kray? I had a request to be able to make matt renders in kray via shaders,etc. Is it possible to support the option for matt objects Image
Even if I make my objects completely black via surface so it doesn't show up in render, I don't know a way to exclude it in alpha. Constant black is not supported. Really this is important for compositing. Without alpha control its impossible.
Maybe someone knows a way via nodes?
Re: Matt objects
geo_n wrote:Are there any updates on supporting matt objects in kray? I had a request to be able to make matt renders in kray via shaders,etc. Is it possible to support the option for matt objects Image
Matte object is supported, Alpha channel settings not yet.
geo_n
Re: Matt objects
Post by geo_n »
Jure the alpha setting is the most important. Please priority one. :mrgreen: :mrgreen:
I can tell you that kray is faster at rendering particles and volumetrics and cleaner too. I want to use kray for effects, many people might not know this fact that it renders fire effects faster but its completely unusable without those matt options. :mrgreen:
Re: Matt objects
geo_n wrote:Jure the alpha setting is the most important. Please priority one. :mrgreen: :mrgreen:
Ok I'll try to push it forward.
geo_n
Re: Matt objects
Post by geo_n »
Thanks. I couldn't believe how fast it was rendering fire and smoke effects compared to lw. I'm excited to use it on some projects. We switched to fumefx long time ago. But maybe this could change things.
geo_n
Re: Matt objects
Post by geo_n »
kray renders particles 2-3 times faster. shame the alpha is not supported yet.
png with alpha attached.
Re: Matt objects
Nice indeed. Not many users use hypervoxels in kray hopefully your example will encourage other to try it too...
tajino
Re: Matt objects
Post by tajino »
I have to second that. Kray needs to be able to render alpha set in item properties and also alpha that is set in surface alpha setting. This should be on top priority.
Thanks.
khan973
Re: Matt objects
Post by khan973 »
Yes, Support for real alpha is really needed!
geo_n
Re: Matt objects
Post by geo_n »
This should be highest highest priority and probably not so hard to code but so crucial in workflow.
