Does Kray utilise the Affect Diffuse / Affect Specular settings on LightWave lights?
Quite often I want to leave the settings I have, but want to disable lights by turning off Affect Diffuse / Specular to check the influence of other lights.
I've tried this in Kray but it seems to still affect the output.  Does Kray not support this yet, or is it one of those settings not exposed in the LW SDK?
If so, what's the best to disable LW lights without setting intensity to 0%?
Cheers
Matt
							Turning off lights using Affect Diffuse / Specular
- matt gorner
Re: Turning off lights using Affect Diffuse / Specular
No, this doesn't work in Kray.
Best way to disable light temporarely is to uncheck it in Scene editor.
						- matt gorner
That'll do me fine, thanks Jure!
