Hi.
I've just purchased Kray for my studio and i'm having a problem. If i try to render a frame I get this error:
Unknown command: "Generic_KrayFrame"
I have Lightwave 9.2 and Kray 2 and am working with a MacOSX 10.5.2
The Kray options window opens fine, so it appears the Kray plugin is installed. It's just the render button that causes the error to pop up.
I hope someone here can help. I've done a thorough search of the net and can't seem to find anything regarding this problem.
Thanks!
						Kray error - Unknown command: "Generic_KrayFrame"
				hivecreative
Re: Kray error - Unknown command: "Generic_KrayFrame"
You need to remove and delete completely old version.
Generic_krayframe is from previous version and if you have her files on your lightwave directory is possible that can autodetect.
