hdri
Re: hdri
please try sunsky and sun. HDRi is not good idea for exteriors (better is HDRi + sun). But Sunsky give as better controls. You can add POWER 2-3 in Kray menu (so You increse power from sun and sunsky. I thing in this point LWF gamma is the best for exteriors (You can try gamma in Kray 1.8  and same gamma in LWF, becouse 2.2 is a bit too bright).  Exponential is good too but make too washing colours and too strong kill overbright area...
						Re: hdri
thanks johny
i followed your advice:
gamma 1.8 and power 0.2 (because power 2 is too big)
sun with area light 100% inverse distance quality 5 rgb 243-232-207 no krayphotomiltipler
sunsky turbidity 4 brightness 150% saturation 80% gamma 3
This render is better?
Re: hdri
Whatever works best for you. Both can be good and both can be bad...talats wrote:Hi guys...
there's something I don't understaind: for exterior rendering someone says that for enviroment light is better a lumiball, someone else says is better sunsky... wich is the better thing?
Re: hdri
I thing the best is Sunsky+Sun (better color control....)
