Some more interiors
richardo_forum
Some more interiors
Post by richardo_forum »
Hi krayer's
some interiors from the last few months..............
they rendered in around 3 hours and at an average res of 2500x1400............
hope you like :wink:
thanks
richardo
Re: Some more interiors
Very nice work! congrats!
On second image the floor texture seems a bit too lowres I think.
Btw. did you try local oversample to get better indirect shadows?
Cool!
stretch
Post by stretch »
Really nice feel! could you tell us about your lighting setup?
the first image is very good but change the texture floor!!!
what's light system? :D
richardo_forum
hay
thanks for the replies guy's................
yeah i see now that i have a low res version of that floor texture on my server, must change it out for the high res version........ :oops:
i will post the set-up tomorrow when i get some free time but its very simple............
thanks again
richardo
richardo_forum
here is a screen shot of the first render...............
and here are the settings
kray_settings.zip
(552 Bytes) Downloaded 362 times
jure: i have'nt tried to render using local oversampling yet but is it an advantage when u have
area lights in the openings as they cast pritty good contact shadows?
what kind of settings would be a good starting point, so i can try it out??
richardo
hi richardo
thank you for explanation :D
joreldraw
Post by joreldraw »
When you tell "Sunsky whith 300% intensity" is this Sun intensity? or how you increase the sky power?
richardo_forum
joreldraw wrote:When you tell "Sunsky whith 300% intensity" is this Sun intensity? or how you increase the sky power?
sunsky is the shader from dpoint and i used this for the environment in this scene, ie a textured environment in the effects tab in lightwave.
the sky power is controled through the intensity tab within the shader settings.
joreldraw
Post by joreldraw »
I have the plugin but i don´t see intensity for sky.
The plugin have 4 tabs, but no option for sky intensity.
Are you talkin about layer opacity?
Thanks
richardo_forum
you control the sky intensity with the brightness value. also u may want to adjust the saturation value a little.
depends on ur scene and waht effect ur going for...............
joreldraw
Post by joreldraw »
Ok, nice ;)
thanks
