Virtual Tradeshow Booth
florian
Post by florian »
Hi there,
just finished this virtual 360° booth. Its the booth of the company raumplus at the iSaloni in Milano, Italy.
Rendered with Kray.
Cheers, Florian
Re: Virtual Tradeshow Booth
mmm
for a small dimension of space there is a big prospective distorsion, so there is an effect as hadid's architecture prospective view.
the floor have black point and when move the view there is a flickering effect....
florian
Post by florian »
nico wrote:mmm
Not much you can do here besides zooming in.
Where do you see black points?
Cheers, Florian
i think the problem is for small dimension of cabin but is'nt a problem this.
for "black point" think you have use a texture o procedural for floor surface of interior space.
when move the camera as floor yellow and black for example there is a annoying effect, but it's resolved if your floor is with only one color
the problem is into the small dressing room
the wall with colours tassellation is fantastic!!!! :D :mrgreen:
this is the effect with floor yellow and black and witout black point
Can You share surfaces velvet from cloaths?
Very good and clean work!
florian
Post by florian »
Johny_quick wrote:Can You share surfaces velvet from cloaths?
Thanks.
I attatched the cloth shader. You can also add another gradient in the color slot and you might need to reduce diffuse based on your light setup.
cloth.zip
(10.7 KiB) Downloaded 358 times
