360 rotation test, cube-house
				RogerNyheim
rotation with shared GI, rendered via BNR on single computer.
some problems with shadows, some advice on how i should get good shadows on the house so it would not apear so flat?
http://www.vizwork.no/cube2.mov
				RogerNyheim
Re: 360 rotation test, cube-house
The outside looks nice. the iside is realy flat yes. did you maybe uncheck fg refractions?
				RogerNyheim
hmmm... maybe i should do that... but i want more dynamic shadows on the outside ...
if you see cube1.mov, it's really flat...
some advices?
maybe I could make a pass with ambient occlusion? or is there some other ways to do it?
some advices?
I see yes... the shading is just too flat. What settings did you use? Did you try uncached to see how that looks?
roger...your exterior lighting is very good....can you show as obtain it?
i love this test
						i love this test
				RogerNyheim
could i render uncached animation without the disco-fx ? (flickering an dancing blotches)jure wrote:I see yes... the shading is just too flat. What settings did you use? Did you try uncached to see how that looks?
				RogerNyheim
I'ts quite straight forward... I have a Lightbox around the scene... sky-plugin... one Area-light with inverse distance...nico wrote:roger...your exterior lighting is very good....can you show as obtain it?
i love this test
I could post my kray-settings if you want them?
Yes, use shared GI just like you do with cached.RogerNyheim wrote:could i render uncached animation without the disco-fx ? (flickering an dancing blotches)jure wrote:I see yes... the shading is just too flat. What settings did you use? Did you try uncached to see how that looks?
ohhhh ies post the setup.
at this moment in forum gallery of kray the best work exterior are your and jonhy.
so i can study the good set for exterior.
