exterior
Re: exterior
Cool! Looks like you are getting the hang of it.
For the grass try johny's preset found here http://www.kraytracing.com/forum/viewto ... =10&t=1446
The stone looks a little flat. You can try and use Relief map node to give a better impresion of depth http://pagesperso-orange.fr/dpont/plugi ... des_2.html
Re: exterior
This is good render. But still need "POWER": better light, better windows glass, grass, vegetables (please forget clipmaps this is old idea) Of coarse now is problem with grass on the hills but You can make on this region big density points + one leaf grass.
Re: exterior
I thank you for your valuable advice. I will improve in the next render
