What's wrong with colors?
Why all of my work is green? I set only walls to be green and I don't know what I can change in kray setup to do it right.
							Problem with giving colors to onother objects
Re: Problem with giving colors to onother objects
You need DESATURATE SHADER (not avilable in OLD Demo Kray). This is standart shader for reduce strong bounce colurs - You can reduce this problem from 0% to 100%(btw. avilable in V-ray too   )
btw. You can use
recurse 8; in tailer cmds
this reduce Your colours
  )btw. You can use
