I'm looking to try out Kray's new animation GI cache, and I've got a scene that I would think would render out no problem, but....I've got a problem. Basically it's just the USA flag surfaced on the Z axis to a polygon, but when it renders in Kray it renders it tiled. See image attached. I've also uploaded the scene.
EDIT: one thing I can think of, is that the object that the flag poly is set to 0.014 in Layout in size. I had to shrink it to match the animation pulled in on the robot.
Render error with simple surface image mapping
- Podium scene error.zip
- (609.12 KiB) Downloaded 256 times
Re: Render error with simple surface image mapping
Let's see 34 views....there must be some one whose posted some help....
Geez, thanks guys.
Geez, thanks guys.
...moment....Larry_g1s wrote:Let's see 34 views....there must be some one whose posted some help....
Geez, thanks guys.
I have normal renders both: Kray/Fprime
If You have error try put this flag as UVmap, maybe is small bug in Your version Kray.
Thanks for checking it out. I'll try that. It renders fine with LW.
EDIT: UV worked JQ, thanks.
