kray grass test animation gi flickers
did a quick test. settings are high. I also put krayshader on flatareas with fg max 2000. but gi flickers in motion. any ideas how to get rid of it?
quicktime video
http://rapidshare.com/files/157598308/test.mov.html
						quicktime video
Re: kray grass test animation gi flickers
Hmm you will neet quite a lot of AA to make the flickering gone....
Hi jure, actually i'm more concerned with the gi flickering of the white areas. The shades and shadows are not smooth even when cache is on. Dancing gi samples. photons is 600000 and fg is 100/2500.
anyone using kray for animation give tips on removing those gi flickers. Upped the setting again but still flickers
http://rapidshare.com/files/158201453/garden_1.mov.html
You are missing the first tab, with the cache irradiance settings. You should have the sharing of Gi "Shared for all frames" and mode next to it checked as "update".
Seems your Gi is calculating each frame differently, which causes the flicker. it's got nothing to do with the AA or FG setup...
That did it. Its much smoother. The main thing I notice though is theres some type of banding across the screen. Not sure what it is.
very smooth. now if kray can do moving objects in animation it would be so great!! interpolated is not good.
http://rapidshare.com/files/161085615/g ... l.mov.html
FSAA G3 Mitchell - this is minimum for You....geo_n wrote:very smooth. now if kray can do moving objects in animation it would be so great!! interpolated is not good.
It can - in next versiongeo_n wrote:very smooth. now if kray can do moving objects in animation it would be so great!! interpolated is not good.
thanks johny- is that for better AA
jure- does that mean the next point releases or kray 2.0?
point release...geo_n wrote:thanks johny- is that for better AA
