"Livingroom" by johny
Hi Silverlw. My verion of Livingroom. My setup light, gi, Kray.
Time render is long (6 h without BOTH).
Post by silverlw »
Nice to see your example. What values did you use? Have you used your usual well proven technique with photonmapping? 6Hrs sound very long and i miss shadows around/behind the paintings on the wall.
Silverlw wrote:Nice to see your example. What values did you use? Have you used your usual well proven technique with photonmapping? 6Hrs sound very long and i miss shadows around/behind the paintings on the wall.
Yep shadow around obj. (paintings) is problem i used GI from Skaydome and Area in window. But in this next render used only two Area in windows and one sun (ONLY!) Thans for critics!!!
