Why do you need them in separate layers? Take a look at wiki for instancing tips.
The render looks good. Maybe just adjust the contrast a bit and add some randomness the foliage. They look exactly the same in size and orientation.
The grass looks good. What did you use?
Render time, pc specs, other info?
The leaves are in the second layer, for clipmaps, the whole tree model is on one uvmap. Of course i could  change that, but i was hoping there was another way around, i use HDinstance usually.
Ill post the image in PS a bit later, im trying to get some more atmosphere out of the render to start with.
The grass is a simple texture with a few procedurals, looks ok from a distance. Im still thinking about close range grass solutions, it seems that the only option for kray is with a lot of parallel planes, Pavlov did some tests on the newtek forum a while ago i think. I was intending to use kray for animations, so the grass needs to be compatible with that (eg. no postwork like on stills).
As for the render times, im not sure exactly, it took about half an hour on a 8-core 2.8 Xeon... which i think is a lot, although i didnt mess with the settings for this particular image, just medium preset and photon mapping without caustics, RRL is 24. There seems to be a problem with my model as a lot of things get it to crash. Turning on causitcs for instance, delta node on the window panes or the path tracing diffuse model.
