I'm getting an error rendering a camera animation. I set keyframes for the camera and try to render the frames but kray keeps saying
Input krayport
skipping frame done
skipping frame done
skipping frame done
no images to render
Press esc to quit
I can't make it render an animation but it renders if one by one. This is second time it happened and before it was a different file.
							kray script error
This is kind of "bug" to me too, it happens when you have already rendered frames of same name on the same folder...
So it helps to render anim files into one empty folder created for it only... It skips already rendered frames (if same name appears)...
And if you need to fix something, render again to another empty folder, or delete the previously rendered files...
It does not complain about this when rendering a single frame, but when rendering sequence, it happens.
				darickster
