Saving to JPEG
dballesg_forum
Saving to JPEG
Post by dballesg_forum »
hi,
How you can make Kray to save the render to a jpeg directly instead to png or so?
I searched on the forum, but I couldn't find any reference on how to do it, except for the comment on the latest beta saying that jpeg saving was fixed.
David
Pheidian
Post by Pheidian »
I think it's upcoming feature in the next release or something... Just keep waiting!
erwin zwart
Re: Saving to JPEG
Post by erwin zwart »
can you try readding kray.ls? I think it should be there in OB6.5
dballesg_forum
I looked to the kray.ls and I couldn't find anything about jpeg. I saw the line where declares the saving formats and it is not there.
Why Grzegorz doesn't use the Image I/O mechanism on LW so Kray we can use all the format that LW can? I think it is doable.
That will alllow to save on .exr format for example if someone has the OpenEXR plugin from LightWolf.
David
Post by silverlw »
Here is latest kray.ls so you get save jpg functionality.
Kray.ls.rar
(19.17 KiB) Downloaded 382 times
erwin zwart
dballesg wrote: Why Grzegorz doesn't use the Image I/O mechanism on LW so Kray we can use all the format that LW can? I think it is doable.
David
strange enough I can do exactly that when rendering with VirtualRender, this gets 96bit image from kray and saves it with any of the LW image savers. Funny enough that is "limited" to 2GB maximum (also in LW64) that results in a 16000x11000 HDR or EXR , large enough for most of us ;)
TrueArt Support
Post by TrueArt Support »
VirtualRender http://virtualrender.trueart.eu
Run Kray on your renderfarm in super hi-res!
erwin zwart
TrueArt Support wrote:NewTek fixed this limitation
https://secure.newtek.com/FogBugz/defau ... 7_JYGZIKGM
now the sky is the limit!!! Good to know for when I want to render a highway billboard in 300dpi in kray on Virtualrender ;)
